Re: 180 SS New to the Forums.
I did re-pull the consoles and removed the upper half of carpet that I glued down to those consoles. I glued them little too well if you ask me. It didn't come off without a fight. I also pulled off the bow support for the bench seat that will go up front. I am going to measure out and order the marine flooring tonight. I would like to finish that as soon as possible as it appears my schedule is getting busier this summer. :facepalm:
Thanks Dozer! Looks like I'll hit up one of the 5 locally haha.
This also gives me an idea of maybe adding padding to certain side panels. Maybe an inch or two along the sides of the bow, I could also make some cushions that mount to the consoles as they were in the original. I would just use my epoxy coated plywood for a good rot free backing. I would want to continue the vinyl theme in the boat otherwise I think it would look weird without continuing the vinyl color in more places.
I was thinking about cleaning and repainting the OB. I saw a few articles on here and have an idea on the process. I plan on stripping all loose paint and repainting. There was an informative write up here.
Painting 70hp Johnson OB and I want to make sure I get this correct, as best I can.
I do need to know where you guys get decals. I saw a guy on Ebay but they aren't the factory standard. Any suggestions?
Also going to paint the spots missing or needing paint on the hull. I plan to use the same method as I use for the OB.
As for keeping things off my fresh paint. Possibly pick up clear drop cloth, tarp below the area, build a box frame with a double lap door. Add some fans, and it will almost look like a giant saran wrapped box and man it's going to be hot in there! We'll see!
