DirtyHarry83
Thread starter- Joined
- Jun 5, 2012
- 305
Nice job re-purposing that wood DH! turned out really sharp!
Thanks, I really like how it came out. Now I am trying to find excuses to add more pieces like that on the boat.
I know a local place that sells teak and I am tempted to get more pieces to make more parts for the boat. Note, they will likely be added after I get the rest of the hardware finished. I have some ideas for under gunnel support mixed with rod storage. The starboard side won't be of sufficient length for 6+ foot poles, but I could probably store a boat hook, gaff or fish net on that side.
Initially and for expedience, I think I'll probably just start with some under gunnel templates made from plywood, epoxy seal them and add paint.
Finishing the consoles, I have some small amounts of trim I want to add to the front of the consoles to make that carpet wrap look better. I have the materials, just need the time. I also have to wire the gauges, which should be pretty quick.
Some of whats to come:
I've added my own transom saver for my fish finder transducer. The materials I used were a marine epoxy, stainless steel bolts and a plastic cutting board. I counter-synced the bolts and applied epoxy over top to make them permanent threaded rods (and to keep the SS away from the aluminum) for the lock nuts I'll use to hold down the second plate that holds the transducer. I wish I had thought of adding a bracket while I was having the welder fix my bow. This should work. For additional strength, I plan on adding 4200 behind the transducer plate for added flex support while in powering through the water. The 4200 is probably overkill but if I have the stuff, I might as well get it done.
I just did not want to add holes into the boat that might cause a problem. The added benefit, is if I get a new fish finder I can use the old transducer plate I made or just make a new plate and put new lock nuts on the epoxied plate.
Working at a tortoises pace. I'll get the boat done some day.
Last note. I am going with the name Kickin'&Screamin the lettering style I've liked so far is called paint brush.
Kickin because the boats still around and Screamin because 2 strokes don't go along quietly.
I forgot to note, some boat parts came in today (including a new steering wheel). Cannot wait to get that on and done!
