18ft aluminum boat v hull
BoatLover13!
Does anybody know what type of Jon boat this is, it is 18ft. I also would like to know what the max HP it can handle.
Does the hull have a number stamped on stern, starboard side?
Ifishmuskie2
Looks to be 1960 to 1975 ish. When there were lots of companies making boats.
Should be good for a 30hp once you fix the transom.
handles look like old alumacraft. transom has been modified (cut down)
can always use the CFR calculation to determine the maximum hp for a 18' tiller steer boat. just need the transom width.
transom looks to be about 4.5 feet wide and under 20", so ~ 35hp
Texasmark
The chines are rounded like Alumacraft boats of the period. Not sure about the brace across the bottom in one picture and the top cap at the intersection of the chine and the transom looks like their's too. Alumacraft was popular in my boating circles at the time and I had a 12 footer with a 7 1/2 Merc. Largest I saw at the time was a 16 footer.
JimS123
The transom corner posts and the seat brackets look just like my Sea Nymph. Post a pic of the side profile.
Regardless, it's NOT a Jon boat. It's a V-hull utility.
Measure the OAL and beam EXACTLY and I'll look it up in my collection of catalogs.
DeepCMark58A
Alumacraft made a Queen Marie in the late 50's early 60's that was longer/bigger.
DeepCMark58A
That is an alumacraft corner handle. The handle inserts into the gunnel.
pretty sure Jim is right on it possibly being a sea nymph. dont see a 18' in what I found.
