870 Expressmag
- Joined
- Sep 7, 2011
- 154
ok heres a little back story on this motor, i bought it with a 15ft meyers aluminum boat in june 2012. the motor didnt run right at the time, we cleaned and rebuilt the carb, replaced upper crank seal, points and cond., fuel pump and lines. Had it running but couldn;t get the lean sneeze adjusted out, took it to a marina and they adjusted the timing and sealed up a welch plug and the motor has run like a dream ever since, including trolling on a no wake lake we go to. now this year it has started acting a little funny. the motor always starts right up for me. we can go out fishing and start the motor up and move 3-4 times, but about half way through the fishing trip, at least once trying to start the motor it will start, kick a little and pop, if i get it into gear fast enough and give it some throttle it will pick up and we can plane out and the problem goes away, usually for the rest of the trip. sometimes it takes a couple times starting it to get it to run enough to get it into gear but usually once or twice is enough. but it doesnt happen all the time, i have no problem most of the time trolling this motor around at 2.5-3mph per my lowrance. last weekend dad and i were back out on the no wake lake, and we kinda figured something out. as we were trolling around i could hear the motor rpm start to climb, like an air leak on a chainsaw or other 2stroke, etc. then start popping, if i rev it up (which your not supposed to do on this lake) i can get it to clear up, the other thing that clears it up, is my dad would pump the fuel line primer bulb and the motor would settle back down. so we are thinking the fuel pump isnt pumping enough fuel at low rpm? but i still dont understand why it acts lean. however if that were the case it shouldnt do it to me randomely on the other lakes where i dont troll at low rpm like that, and in the bigger lakes it always does it to me on startup, once i plane out and clear it out i'm good to go. dad thinks there is an airleak somewhere in the fuel line from tank to motor and the fuel pump starts sucking air once in a while. i dont see any evidence of fuel leakage inside the cabinet of the motor, and no oily sheen on the water so i dont believe i have a fuel leak. we are kinda on the right track to finding problem but dont know exactly and i dont wanna start throwing parts at it until i get some advice. thanks for any help
