kingsnakejr
Thread starter- Joined
- Jun 16, 2008
- 70
If you spin the prop shaft on my 18xd merc you can tell the shaft is bent.
Although there is no noticeable vibration in WOT and l/u gear lube is clear with no metal or water present. I can't afford a $300 prop shaft. A machine shop could straighten the shaft but the heat process to straighten it will make it weak and could be easily bent again. Would I be unwise to run it until an obvious problem arises?
