19.5' Crestliner Norseman DC project boat...
Status
Not open for further replies.
Mr850i
Re: 19.5' Crestliner Norseman DC project boat...
Well she's almost stripped all the way. I did decide to repower the boat. I just bought a doner boat. It has a 1990 mercruiser 3.0ltr with an alpha one outdrive. Its a 130hp but I'm sure that will be fine even though the boat is only rated for 120hp. The motor and drive only have 114 hours and are in perfect condition. I'll get some pictures up soon.
OLLTINMAN
Sounds like you got a good start , keep us posted :)
Mr850i
When repowering your boat is there a formula for the correct location of the outdrive? How do I figure out the exact height of the outdrive?
Woodonglass
You do realize you must fabricate a totally new transom and cutout a new outdrive opening for the merc? The cutout and mounting is VERY specific. This will help
http://forums.iboats.com/showthread.php?t=449689
I highly recommend to contact Don S. on the MercCruiser forum and ask for his advice before moving forward with this.
MercCruiser Forum
These will help too!
http://forums.iboats.com/showthread.php?t=329915
http://forums.iboats.com/showthread.php?p=2258649
Mr850i
Is it necessary to use "marine grade" plywood when rebuilding a transom?
reavesga
Yes. Use the best ply wood you can get your hands on. You will need to laminate two or three sheets together to get the correct thickness. You can use epoxy or Gorilla glue to do the laminating, but screw the sheets together to make sure you get them together nice and tight. Once they are glued together pull out the screws and coat everything in epoxy.
Make sure the aluminum is in good shape. I cleaned my and then painted it. Don't worry about filling the hole at this this point. I fitted my transom plate and found that aluminum was NOT flat, the wood was. So I very slowly pulled the wood and the boat together with long screws. This is important because the transom must be flat where the drive is going to install.
Next I filled the hold where the OMC drive went with 1/8"plywood and yes soaked it in epoxy. Then I made an adapter plate out of 1/8" aluminum that picked up all the old rubber boot screw holes and sealed that in place using 3M sealant. I believe it is 5700 but would have to check on that. Then, followed the instructions. Made a template and cut the new key hole. Installed the transom components, drive, motor, etc all per the mercruiser instructions referenced in an earlier post.
Pictures at http://1974norseman.blogspot.com/ look in the July - October 2010 time period. I got the drive a little higher than I would like so take careful measurements. Basically, if your Crestliner Norseman DC is like mine you have an I-Beam running up the middle of the boat. The mercruiser setup should sit right down on that beam. I put mine about 1.5" above that beam, and that put the anti-cavitation plate about .75" above the bottom of the boat. You want it even with the bottom or actually below. My setup runs great, however, the 4 blade prop is a must. I never did get a 3 blade to keep from cavitating as the boat pushed over while planing. Also, have to make sure the drive is all the way down, or I get a little cavitation. I am certain my problem is from having the drive too high. However, using the 4 blade prop and running about 3000 - 3500 RPM all works great. I have put the hammer all the way down and she will run 32 kts at 4500 RPM with the 4 blade.
Now, once I am on plane, I can trim the bow up and down with no problems. 4-Blade does great.
mciulla
How is everyone doing? Good I hope. I have the opportunity to pick up a 1976 Norseman with a 165hp straight six. I really do not know anything in regards to this model other than what I am being told from a friend who is selling it to me. It too is going to be a project for me like most on this thread. It does appear to have the same out drive as pictured above. Can anyone advise me of what make motor was used in this model? It is very difficult to find any information on the 76 Norseman II, so any help would be greatly appreciated. Also it would be great to see any recent pics of all the projects so that we can see the progress! Thank you everyone in advance.
Also I would really like to build a hardtop for the cockpit. Mr850i do you or anyone else have any pics and info on building your own hardtop?
bmartin5
Hey everyone!!! Dont know if anyone has any interest, but this project has fallen into my hands now! Just picked her up today and went down to register her 😀. Its gunna be a group effort with me and a buddy and most likely converting it to an outboard boat with a bracket. This should be fun!!! A very slow build thead should be popping up soon but wont be any kind of fast cuz we are both college students. Should be fun right???
GA_Boater
Yes, it is best to start a new thread on the build. From what was in the first few posts, all that has been done so far is a strip job.
I'm going to close this thread to let it go back to sleep since she is in new hands.
Status
