secretariatslew
Thread starter- Joined
- Apr 6, 2011
- 42
What should I check when inspecting the ignition components? I have tons of parts for the later 50's and 60's OMC ignition but it appears that maybe only the condensor is the same. The coil faces in instead of out and the points do not move when i rotate the shaft. Everything looks to be in remarkable shape- no cracked coils. But I do want to replace the spark plug wires. Should i tap out the coil from the plates and drop a brand new coil into the old plates? the current plug wires look to be sodered onto the coil. Any direction- link to a good resource would be appreciated.
