1947 Sea King 2 stroke 5hp
Hello every1 new here I'm trying too find out if anyone could help me find points for my 1947 sea king it's a montgomery ward 2 stroke 5hp model 74gg9012 serial # 152352 had it running till a point bracket broke
brim_buster
Check with Johnson Evinrude OMC. Napa might have them as well. They are pretty common or look at this...https://www.ebay.com/itm/160980126950?hash=item257b29cce6:g:KrIAAOSwJc9acMfw
That was made by Johnson / Evinrude.------Visit ----aomci----Lots of folks will have these breaker sets.-----Should be easy to find.
Johnson for gale what I'm trying too do is get the points set so I can get it back 2 running again I'm trying to find the specs too set them
I have motors with those breaker points and some breaker points like that in bins.-----Worked on many of them.----Fact----The throttle position does not matter.----No it does not !
440roadrunner
This is correct, because you are setting the points relative to the mag plate, which moves. YOU CAN check total timing if you know what that figure would be, but I don't. This would be with the mag plate full against the stop
