Re: 1950 12 hp Elto outboard exhaust question
I will double check the numbers on mine, you have a wealth of knowledge on older outboards, tks for info. I replaced the bent plate over the ehaust holes in the exhousing, and run it in the barrel, make a big difference in the noise level, to look at them you would think they were factory done, as if a template was used on both sides following along a arc and curvature of the housing.
Tks again for info TN-25
