JTKelleyiii
- Joined
- Feb 19, 2012
- 49
I am in the process of resurrecting a 1950 7.5hp Fleetwin Model 4434. My question is once the gear housing cap and clutch lever support collar are removed should the prop shaft slide out easily? I can pull the prop shaft out partially then the clutch drive spring starts to expand indicating to me that something is hung up. Since I am unfamiliar with this setup would appreciate some guidance from you experienced members before I get more "forceful" on removing the prop shaft and screw something up.
Thanks
Thanks
