1950or1952 10 hp johnson outboard not getting no throttle
sky9582029
I had the fly wheel of and put new coil and new plug wires it will not rev up plugs got real sooty when running seems like over fueling is the carb air setting on this unit same as my 58 rude:confused:
wbeaton
Re: 1950or1952 10 hp johnson outboard not getting no throttle
What is the model number. 1950 and 1952 have completely different magnetos. I assume you have a 1952 since you said you changed the coils.
The jet settings are the same, but they are located in different places. If turning the high speed jet makes no difference then you may have to clean out the carb. The float may also need repair/replacing. That carb is obsolete and hasn't been used since 1953. I don't envy you if you have to open it up.
MrGED05
A good long soak in carb cleaner and many blasts of compressed air and a toothbrush and Q tips and more cleaner will remove the "varnish" that old fuel can leave inside the carb. No sharp or metal objects should be used in the cleaning process. Do not soak any rubber or gasket parts, they'll not survive.
Gasket sets for that carb are difficult to find. Take the originals to an auto parts shop and get replacement gasket sheets of the proper thickness. Trace the original gasket form onto the sheet, ever so carefully use an exacto kinfe to cut out the replacement.
The "O" rings and such can be found by tiral and error at an auto parts store or a good plumbing supply store. Don't use the old ones, they're not likely to seal well again.
The common problem with these carbs is that someone got "ham -handed" with the needle valve, overtightened it and deformed either its seat or pin. I have no help I can offer for finding replacements other than the maker, these parts were used on a number of different years of engines and carbs, they'll know which ones you need.
sky9582029
thanks ill have a look at the carb they dont look to complicated i had the low speed jet out it dosent look to bad the plate with s.no is gone to find mod. and year
wbeaton
Should be a silver plug the size of a quarter on the side of the block. Probably has a serial number on it. What is that number?
