1950's Wagemaker Wolverine wooden boat restoration ...
sphelps
I thought about both of those uses .. Can’t see where it would be needed on the steering cables and there to short to span for a canvas cover .. Seems there is a front and a back because one side if finished nice and slick finished and the other side is unsanded and less finished ..
sphelps
My shoulders are killing me ! :faint2:
‘But starting to make some progress on the sanding ..
Been using 60 grit with the RO sander mostly . Will finish up with 80 ..
From what I have read you don’t want to go way down past that and make to slick for the varnish ..
Little by little I’ll keep pecking away at it ...
Woodonglass
I think i'd finish with 100 grit. You'll have a smoother finish AND plenty of BITE for the varnish. If you spray the varnish( I highly recommend you do) then thin it about 10-20% with MS for the first coat. Then Full coats for the next coats. I'd put down at least 3 full coats and maybe 5. What Marine Varnish are you using. I think Epiphanes or ManOWar are two of the best.
sphelps
I picked up a quart of Epiphanes and some of there brushing thinner . I know it will take a lot more so the door is still open to changing things up if I want .. My original thought was to roll and tip it .. If sprayed will it OP like paint does ?
‘Not much to see but here are a couple pics to at least prove I’m sanding something ..:joyous:
B2077654-5D4E-4E0B-A3DA-7F8EFF42627C.jpeg93941C0D-ABB2-4B70-831B-754D244DD60F.jpeg0C8CCCA3-28ED-4681-8E67-36F4D2A9B718.jpeg
sphelps
Good lord at the crud on my lens .. :facepalm:
You can really see the bunk board damage on each side ..
I think I am going to epoxy and paint a good bit of the bottom ..Pretty much just what will be under the slat decking ..Thinking a nice light brown or sandy cream looking color would be nice ..
kcassells
Looking like a diamond in the rough! Tough calls to make for final finishes Sam. I like that wood look. :D
mickyryan
i had a good color if i can find it it was like a mahogony like the old color they used to use on wooden boats kinda red/brown but looked awesome
sphelps
Yep Kc , this is some tough sanding it sure seems like .. Really hard to get it down to bare wood .
‘And on the veneer it still looks a little dingy and spotty/blotchy looking . May have to stain idk ...
sphelps
Micky I was thinking more light brown and not so reddish brown ..
I got it in my head and will know pretty much when I see it ..
Yall just don’t know how close I came to painting the bottom yellow instead of white ..:lol:
mickyryan
only reason i went with the reddish brown was because it matched my stained mahogany luan id go with whatever closely matches your natural woods final color :)
zool
U may get some peel or runs, but u need to let each coat dry fully and sand between coats, so you u can keep it a check...Its air cured like oil paint. You can touch up any runs with good brush between coats too, to save some work. If u dont sand, the next coats will slide down and run. Also, sand horizontally, to create shelves to hold it up on verticals.
Looks like u just built it Sam!
Woodonglass
That's why I suggested multiple coats you want to cut back on the volume on your gun and cut back on the psi. That will help the vertical areas from running. I don't have much OP when spraying it. Try to spray with low humidity if that's possible in Flow-REE-Duh!!! I spray mine at about 30 psi. You can roll n' roll it just like paint and get great results. I'd recommend using a TouchUp gun. They have a 1mm tip so you get a Ultra fine mist. My HF touch up gun works great for Varnish.
zool
I'm a fan of the HF touch up gun too Mike....I heavily thin whatever product and lay xtra layers....and only have to sand to keep it level.
sphelps
But what about the varnish at full strength.. Last few layers should not be thinned right ?
zool
The main benefit I see for spraying is it gets in all the nooks and corners well. You may want to brush apply the final coat(s) undiluted to get a hard shell finish.
Im painting a large concrete barn right now, I sprayed it originally to change it from white to red and get in all the cracks, now the final coat im doing with just a brush...nice and thick..it coming out great.
oldrem
My HF touch up gun sprayed Helmsman Spar Urethane full strength at 30 PSI with no issues, so would think it would handle the varnish just fine
