jib mcjibberson
- Joined
- Aug 3, 2009
- 3
I recently replaced impeller and cannot get water to come through the tell tail hole. When i put hose to tail hole, water comes out the leg. when I put hose to the impeller housing water comes out the tell tail hole. when I assemble and test while running in a barrel, nothing. Water tube doenst appear to be blocked. When I run in a barrel water sputters out the exhaust grid on the leg and I can feel exhaust pressure comming from tail tell but no water. I'm stuck and need help. This is my only motor and need to get it going.
