1952 Johnson TN28
JRegier
Alright old motor guys, I'd appreciate if you would chime in.
Simple enough question... Would a TD20 carburetor fit a TN28? (they look amazingly similar) annnnd I would think that a TN27 carb would also fit...
And I know Lloyd is floating around here, if I could get his contact info for some of those leather primer washers that would be great! thanks!
HighTrim
Re: 1952 Johnson TN28
You will need this.
New Page 1
Send $7.00 per set (cash only, no checks) and SASE (self addressed stamped envelope) to: Lloyd Lautner, 9289 North Long Lake Road, Traverse City, Michigan 49685
JRegier
Thanks Chris. Shameless self bump! I need to know about the carb before I buy one!
brim_buster
the repair manual says there are 3 different types of the type 1 carb that went on those. the chokes are different and apparently the float bowl. These carbs were used from 57 to 64 up to the 28hp motors. dont know if that helps or not:facepalm:
TN / TD carburetors are totally different and have a primer system and a seperate slow speed mixing needle, thus no choke like carburetors in 57 to 64 motors.----TN models have a nuetral clutch.-TD models may be direct drive.----Carburetor would be similar between the 2 models.
JRegier
Thanks, guys. I think it'll be worth $10 for the carb even if it doesn't fit. I DO have a TD20, after all...
HighTrim
You know what, you stumped me on this one without doing some digging in manuals. Ill find out for you though.
HighTrim
Ok you can swap the carb between them.
Some of the TNS have different throttle linkage rods from the magneto, but carbs are interchangeable.
JRegier
Thanks for the definitive answer, Chris! I just popped the LU off and WHEW. I thought the newer oil stunk!
