Re: 1952 QD-13 Johnson 10hp
Yep, QD-12 1951 was the first year of the universal ignition and I believe that the QD-10 of 1949 was the first OMC with the F-N-R shift and the Fastwin of 1950 was the second OMC product with it. As far as the carb kit, I would try Engine Blade and Prop. They have a pretty good NOS supply of parts for this motor and way earlier. I actually picked up a new set of rings for a 1937 Sportsman single from these folks.
As for your condensors, they lay down. The points on these set at .020. just like the modern ones. You may want to pull the push rods and clean them up and apply a fresh coat of grease on them, so they'll work free. These tend to get sticky, if the motor has sat for many years.
The design for the QD model was pretty much the same, from 1949 - 1952, with the exception of the ignition system. In 1953, the QD and the Super Fastwins were introduced with the Roto-grip handle. It was pretty cool lookin on a "fins forward" motor.
1954, the CD models and Fleetwins were introduced with the Roto-grip. Of course, the first OMC with the Roto-grip was introduced on the Big Twins and the RD's in 1951.
