Redeyedwiggler
Thread starter- Joined
- Aug 19, 2004
- 56
Re: 1952 sea king
The shaft rotates inside of the prop when I turn it counter clock wise but the nut tightens when I turn it clock wise.. is that a sign of a sheared pin?
I soaked the nut down with penetrating oil and the nut does spin clock wise but as I spin it counter.. it loosens slightly then the shaft moves inside the prop..
I hope I'm describing this clear enough.
As I loosen it slightly the prop seems to slip a bit more easily.
The water flush screw: can I just replace the grease at the end of the season.. will that remove any water that might be in the lower unit? I assume the water flush is to remove the water in case of freezing.
