beverly
- Joined
- Sep 12, 2010
- 58
Re: 1953/54 Evinrude Fastwin 15HP - Won't Idle
Here is something I thought of. when the control is at START (mid) and if I unhook the butterfly valve on the carb. I can bring the 15 down to an idle and it won't die until the control is at shift and lower. That is what got me thinking it was the coils/condensers/point which in turn got me to remove the flywheel and check everything. Here is a few question the thing that turns under the flywheel to get timing advance.
Can this whole plate be adjusted or is adjustable about and inch or half an inch?
The reason I ask is when the handle is at SLOW the roller that controls the carb. and it starts to open up or close the butterfly valve that connects/touches under the flywheel for the timing advance spark thing/plate starts to come off track and the the roller starts to ride the spark plug wires when the control handle is at the STOP position.
