1953 evinrude big twin tune up help
scot
1953 Evinrude big twin 25hp . dry stored unused since 1961. replaced coils, points, condensers and cleaned carbs. will not start . backfires loudly but no start. what do I do next? Carb settings should be what? points .20.
oldboat1
Try initial settings 1 1/2 open for the idle screw, and 1 open for the h.s. If it runs, let it warm up then adjust settings.
Water pump service is always a first priority for a stored motor.
F_R
Too much gas (flooded) can make it backfire too. Too rich to fire, the gas is expelled into the exhaust housing, where it can be ignited by a cylinder pop and explode with a bang.
You sure you have the points set correctly? I suppose you held the cam down, right?
If flywheel key is missing there likely will be no spark at all to make it backfire.
Crosbyman
After I carefully rewired my 6hp I managed... to switch spark wires :facepalm: ....it never started till I switched them back
so as racerone suggested...check all plug wires sh... happens
I also applied weed ...and grass killer:laser: on my dandelions....wrong bottle :stupid:
my lawn looks different now and wife not very happy
I see folks fertilizing their lawn in the spring and then cutting the grass every 5 days.----I sprinkle a case of beer on my lawn in the spring.as it makes for a lot less work.---------Reason is -----The grass comes up " half cut " already.
scot
tried again. no start. points set- key inn place. pulled a back muscle.
lindy46
Is it still backfiring or not firing at all? If no fire, try spraying some premix into the carb. If it's backfiring, the front-most coil fires the top cylinder.
