I just picked up a 53 fastwin for pretty cheap. It runs when the choke is out but dies if its pushed back in. It took some effort to get it to start but it finally did. The guy i got it from was of questionable mechanical ability and it likely was stored with fuel in the carb, etc. . . The shaft doesn't swivel easily but does move with pressure, so that needs to be greased. The pee hole doesn't push any water out either.
So my question is, what should I do about the carb, impeller, etc. . . What should I pull apart and what should I check before I think about strapping it to the boat and tearing across the lake? I don't want to make any problems worse by running it before their fixed. Also open to recommendations on where to get parts and such. . .
Any help would be much appreciated, Kelpy
