1954 Evinrude 7.5 plug wires and coil/magneto question...
Slimm
I have a 1954 Evinrude 7.5 hp (#7514) and have a few question regarding this motor. (1) I am curious about how to adjust the coils location in reference to the inside of the balancer. I am installing new points and condensors and would like to properly adjust the coils while I am there. (2) Do I need to use a specific sparg plug wire or can I fit a new auto plug wire in place of the solid core wire that is on the motor currently? (3) I checked the cylinder compression and have exactly 60 pounds on both cylinders while cranking, anyone know what the cylinder pressure should be? I have read this forum for a while and am amazed at the wealth of knowledge, I think I found a new home...
Paul Moir
Re: 1954 Evinrude 7.5 plug wires and coil/magneto question...
Welcome to Iboats, Slimm!<br /><br />Just so we're on the same page, balancer=flywheel.<br /><br />-1-<br />The proper way to align the coils involves a ring that fits over the entire armature plate. The alternative way to set them is to make sure their laminations (Surface A) are carfully aligned with the machined faces of the bosses on which they sit (Surface B). Here's a pic, courtesy of Xcusme:<br />
<br /><br />Carfully examine the coils for cracks. They are *very* common, and cause difficult to diagnose problems. New ones are cheap. (EDIT: New coils are cheap too!)<br /><br />-2-<br />You must use only solid metal core plug wires. Although slight, (~1Kohm) automotive 'supressor' wires' resistance is too high for these less than high energy ignition systems. Most Johnny/Rude dealers will have a roll, as well as any small engine repair shop. The original wires don't deteriorate internally like automotive wires, so I wouldn't be surprised if your wires were still good. It's a good idea to replace them anyway though.<br /><br />-3-<br />There is no specification for compression, other than both cylinders be balanced to no more than 10% difference. 60 psi *sounds* low, but I think it would run. You can try decarbing the engine to try to bring that up, once it runs.<br /><br />Hope this helps! Good luck!
wayne h
Master Chief Petty Officer
there is acually tools that adjust the coils where they need to be. i have done it without for years untill i found a bunch of the tools at a local yard sale.it can be done without close without hitting is usually close enough. DONT use auto wires they need to be solid copper wire you local outboard dealer will have them in stock by the foot.auto wires are resistor wires and wont carry the spark like the solid wires will. as for compression 60 is alittle low but was the cylinders dry and did you have it at wide open throttle?? they claim as long as both cylinders are with in 10% of eachother u will be ok. you might wanna do a decarb to the old dog and see it that brings her back to life. this is a great board i have learned alot just from eading alot of the posts.i am but no means an outboard mechanic but i have done all my own work on mine. i know my way around gas and desiel engines but i am still learning about outboards. welcome to the board and remember every boater needs a shop manual
wayne h
hahaha yaa just what Paul Moir said i just hit enter and seen that he wrote almost the same think i did. looks like i am learning more then i thought :)
Paul Moir
Yeah wayne, but I've got pictures! But dang, those posts are nearly identical. :) <br /><br />I just wanted to add a couple things - those 7.5s need to be run at a 24:1 oil mixture, and be very careful never to over-rev the engine. If you follow those rules, you've got a much better chance of keeping the connecting rods inside the crankcase. :)
Slimm
Thanks for the info Paul and Wayne. I am an ex machinest and long time engine builder but new to the old 2-stroke boat motor area. I had suggested to my brother (from whom I aquired the motor) that the machined places on the coil mounts were for alignment so I guess I am not too far out of my area. The carb on this rascal has a low and a high speed adjustment nob that sticks out of the front, any idea where to get replacements as these seem to have been damaged. I have a manual on order and can barely wait to get it. Thanks again for the info.
Slimm
Thanks, I have sent them an email and waiting for a reply.
Paul Moir
Slimm - if you still have a machine shop to use, the ignition coil alignment ring tool measures 4.472" ID, by 5/8ths thick according to the manual. By the looks of it, it's about a 6" OD.
