Re: 1954 Evinrude Fleetwin Aquasonic 7.5hp 7514 Dead cylinder-Need Help
Get a can of fogging oil, shake it good and 'foam' up the carb intake as much as you can.
Try to start.
Even if it does not start, it should be almost equal amount of fogging oil in the cylinders (wet plugs), or you have a problem at the suction side = crank case compression/vacuum.
Try to start.
