55Crestliner
Thread starter- Joined
- Aug 31, 2004
- 192
I finally got my "new to me" motor running tonight, (after I remembered to close the pressure tank cap, what an idiot
).<br /><br />I did a de-carb, but noticed it won't stop smoking (white smoke). The odor of the de-carb is finally gone. Then I noticed there is water coming from the bottom pan. There is a 1/4 inch hole in the pan, and water is STREAMING out of it. I have to assume this is a hole in the head gasket, because the stream lines up with the gasket surface. Why would they have put a hole right there? Is this a common place for a gasket to go bad? I also notice that there is a long dent in the leg, right where the hole is, almost to suggest you would put a screw driver up there for something. Any ideas what's going on here?<br /><br />I took a digi pic of the water, but I bet Paul or someone else already knows what's going on without a picture
<br /><br />BTW, compression is 80psi in both.<br /><br />Motor is running relatively good, but doesn't seem to want to go as slow as the 10 or 18 I have - I bet that's normal anyway - not a big deal.
