1955 7.5 evinrude m#7518 Power head
UPRON
I am having trouble when I put power head back on ? It feels bound up when I try
to pull.On drive shaft there is shock absorber spring that does not fully seat in brass cup washer that sets on pin in drive shaft? any ideas
1946Zephyr
Re: 1955 7.5 evinrude m#7518 Power head
You might possibly have a bad shock absorber in the lower unit, if it pulls over hard.
UPRON
Thanks Some day I might get this motor correct
wbeaton
Was it hard to pull before you started work on it? Have you recently replaced the impeller? Remove the powerhead and see if its still hard to pull.
UPRON
It pulls fine with Power head removed? I have had on/off numerous times as i changed to a LU off CD 15 5.5 hp Johnson.
It has a new impellor but it previously pulled fine? Thanks
wbeaton
Did you use a Sierra impeller? They are too thick and must be sanded down otherwise it will be hard to pull.
kbait
You may have a broken spring in the shock absorber, and it's now binding. Search this forum for fix. I hear people put 'em together and compress, then tig the shell part together so it won't bind, then using a weaker drive pin in case of hitting a rock..
Search and you'll see what I'm talking about.
Good luck!
kbait
I'm talking about the shock absorber underneath the impeller plate.
UPRON
When I put pwr head back on it will not pull unless I leave screws loose? It appears that power head
will not seat down properly?
kbait
If you have the cup/spring and the plastic thing w/oring inside mounted correctly at the top of the drive shaft, you're likely pushing the drive shaft down and the lower shock absorber is binding because it's too 'long' with a broken spring inside. Again, search 'shock absorber' for your year/hp, and you'll get that info. Broken shock absorber would do just as you describe.
