Greg O.
- Joined
- Jan 9, 2011
- 125
This summer I bought a 1955 7.5hp Evinrude. I have a few questions about it.
It seems to have good compression, but when I checked it I was only getting 75 to 80 psi. The engine was room temp, about 65 degrees. I had it running back in August and it seemed to run pretty good, but the carb needs cleaning. What is a typical normal compression for this engine?
Besides the normal stuff like points, pump impeller, lower oil, what other items should be looked at?
I am considering converting this outboard from the pressure tank to a pump system. Is this a good idea, or is it better to leave it stock?
Is there a forum just for old Johnson and Evinrudes?
