bktheking
Thread starter- Joined
- Jul 29, 2008
- 5,057
So I got this motor running tonight, seems whoever put the carb back together after they put a kit in it forgot to put the clip on for the needle, duh, the thing fired up first pull. Not a bad motor for $70. Now the question I have, on all my other motors, 9.9 and 9.5 there is a detent for the shifter to make it shift positive, you know where neutral forward and reverse are cause you feel it. With this motor there is no positive neutral forward or reverse, i don't feel the click as I move it from neutral to gear. I know it's going in gear cause if I do shift it and turn the prop the flywheel moves. Maybe that's how they were designed back then but I don't think so.
My other question- where does the water come out to show that its pumping, it looked like it was coming out from the bottom of the head. Sound about right ?
Any thoughts and thanks for replying.
