1955 Evinrude lightwin 3
dnemeth
Looking for point and plug gap as well as the inital settings for carb needle valves on my 1955 light twin 3 model 3014
Thanks Dave
oldcatamount
Re: 1955 Evinrude lightwin 3
The points should be at .020 (or even a tad less, but not more). the plugs at .030 (make sure you get the right number plug) The carb, start at one full turn open on the low speed and (if it has a high speed needle valve) one and a half turns open.
Vic.S
Points 0.020"
Plugs: J6C gapped at 0.030"
See Joe Reeves' item on the "Engine Frequently Asked Questions" board for the full instructions for setting the carb needle valves
http://forums.iboats.com/showthread.php?t=167352
The initial settings are high speed (lower one) 1 turn out, low speed (upper one) 1? turns.
dnemeth
Thanks you guys rock and its really exciting to get this thing up and running.
