swhobie
Thread starter- Joined
- Mar 10, 2008
- 10
I have a 7.5 Eveinrude 1955 vintage (I believe) and the fuel tank is one of those two line jobs that needs to be pumped to prime the flow up to the engine and then the engine shoots air back to the tank to keep it pressurized and the fuel flowing. My problem is with the little pump on the tank, when you pump it up it sprays gas through the top of the assemply where the little shaft goes up and down as you pump. I am assuming there is a gasket or o-ring that has gone bad. Are there any tips anyone can give me before I just start tearing into the tank to find out on my own.
I hesitate to just tear it apart as when I got the motor and tank, the top plate for the tank is screwed down and there is what appears to be PermaTek blue gasket material. The previous owner says that when he bought it, the owner before him said gaskets for this style tank are no longer available and that is why he used PermaTek.
Any help will be greatly appreciated.
