walleyehntr
- Joined
- Feb 5, 2003
- 6
what is the absolute minimum fuel oil ratio for this old motor. sticker on the cover states amount in quarts and gallons. i figured it to be 20:1. seems like alot! with a premium tcw3 can i run a little leaner mixture without causing engine damage? also at idle it seems to run very rough. i changed points cond. and coils, gunked the carb and installed carb kit and set points and coils to spec
