Yup, good plan. The ones that come shiny don't need it, have sealer built in. Don't put any sealer on the intake side gaskets at carb, etc..
Seems like a difficult and expensive procedure! lol 8 cans!
Expense of the carb cleaner aside, it is not great for you health wise either.
Future, you could probably get someone in your area to soda blast if for much cheaper. And much easier. And much safer to your skin.
Paint remover might have been easier as well.
Make sure you use a self etching primer for the first couple coats. You are on your way! Keep us updated on how it goes.
Looks really nice. There should be a wire running from the 3/8 nut on the front center of the cutout switch up to one of the points connections. I believe one cylinder's coil should ground through the cutout switch when high rpm's occur.
You did a nice job. That will be a nice motor when you get it all finished.
Will this be a tiller model and you just haven't installed the tiller yet?
JBJ
I can send you a picture tomorrow.
I likely have a spare cowl or two as well.
Sorry forgot all about that! Just been so busy haven't had time for anything. It is pretty simple to wire though. Just as the diagram shows.
I personally don't think it would hurt anything to put sealer on an intake side gasket, but just the general rule of thumb. Maybe worried about sucking globs into the crankcase? Regardless, they don't need it unless the mating surfaces are badly damaged and leaking air, leaning out the mix. I have never encountered a motor that I had to put sealer on the intake manifold, carb, etc....
