Minnow00
- Joined
- May 17, 2009
- 33
Recently I picked this engine up and have had it out several times. It seems to run like new except for the duel line pressure fuel system. Motor needs to be pumped at the tank when fuel gets low to maintain pressure so I presume I have a leak.
Since it's time to either rebuild the original system or to convert it to a fuel pump and single line system I am wondering if there are any thoughts pro or con.
From what I have read, the reason pressure systems are no longer used is for safety reasons.
It seems to me if I have to spend about the same amount of money and work I would rather convert now to the single line fuel pump system.
I've searched the forum and was supprise not to find any info on this.
It seems that fuel pumps came into play on these motors sometime in the early 60's and initially they were attached to the sideplate just above the shift arm. My sideplate would need some remodeling if it were to be adapted.
If anyone knows how I can find the part number of a sideplate that takes a fuel pump mount I woud be grateful.
http://www.sschapterpsa.com/ramblings/Converting_dual_fuel_line.htm
