wbeaton
Thread starter- Joined
- Jul 30, 2006
- 2,332
I am in the process of tuning up my 1956 7.5 hp Evinrude. I did a compression test and found 75psi in the top cylinder and 70 psi in the bottom.
I have not yet pulled the head or decarbed the engine, which I will do before I even consider doing a ring job. I will also inspect the cylinders for wear and try to free the rings with penetrating oil to see if that helps.
Assuming, I need to replace the rings and the block doesn't need to be rebored what else do/should I replace when I have the crankcase open? Are the parts still available? I have two powerhead drawings. One is from a 1952 (which looks like my motor) and the other is in my Clymer manual (and doesn't look much like mine). The '52 doesn't show any connecting rod bearings or main seals while the Clymer does. Do these parts still exist? Can the originals be reused if I can't find replacements? This motor still seems to run well so I'd rather run it until it finally wears out completely then to pull it apart only to find out I can't get the parts to put it back together.
