1956 cruiser inc. restore
Ned L
Thank you. Those pics do help a lot (I will have to go over them carefully on my PC tomorrow). I will probably have a list of things for you to look at and check. The poctures pretty well confirm my suspicions as to what caused the issue you found outside.
As far as looking forward to a fix, there are a number of different paths that may come out of this, we'll have to figure out the best one for you. Some of the decision will be based on how you plan on using the boat, and what you expect from it, so you might give that some thought. .....Still to early to talk about the fix though.
When you have a chance, go ahead and remove any floorboards you can and take more pics. Tomorrow I will review the pics you have so far.
If you want to see the kind of work I do on wooden boats do a quick search for my thread on 'Big wooden boat project'.
Ned L
I have looked over the pictures you took and have some comments and things to talk about.
BrittaniB
Been working at cleaning up the tight area up front where I can fit, but husband not so much. 😉 And husband has been working back near the transom. He's pretty much got it flat back there. Gonna go a little bit more on that. Here are a few pictures of my clean up on the front and of the white oak we got cut today for repairs. 😀
https://goo.gl/photos/TDqRtgxvBAFp7Fg6A
https://goo.gl/photos/9wz39TuW6b567mmC9
My husband was wondering about sistering in the ribs. Once it's all cleaned up and all bad pieces cut out and we get some paint coats on, he was wondering if it would be wise to glue pieces in, as well as screwing in? A little apprehensive to screw through the plywood bottom. He was thinking of glueing in place and then scabing in with another on top? Any opinions on this??? And if a good idea, best type of adhesive to use???
Ned L
Wow, that?s looking really good! I am really pleasantly surprised at how good things are looking. The only real suggestion I would make is for the sister ribs, it will really be easier, faster, and actually stronger if you put the sisters next to where the original ribs were, and overlap the sisters and the original ribs by as much as possible. I would say by at least 6? wherever you can. This gives you the advantage of not having to measure and cut their lengths precisely, and also avoids that butt joint (of which you are correct would need additional strengthening).
Not a bad idea to use some adhesive on the sisters, however they really should be screwed from underneath too (as originally done). Don?t worry about those original screw holes not being aligned with the sisters, they can be filled and cause no problems. Something to keep in mind about using an adhesive between the sister ribs and the bottom, any adhesive will hold only as well as the paint is adhered to the plywood. So either make sure the paint is well stuck, or scrape it off to bare wood. (I like something like a Sikaflex ?1a? or ?291? for something like this.)
You will need some way to tie the rib ends to the keel. I have been thinking the easiest way would be either some wood ?horseshoe? shaped pieces, on the side of the keel, one at each rib end and ?capturing? each rib end, or maybe a long thin strip of wood (oak) along the side of the keel with notches for each rib end. ? Does that make sense?
That is good news about working the hook out of the bottom. It sounds like you are making good progress.
sort of crude, but this is what I had in mind for the sister ribs (the sisters being in green).
ry%3D400
