1956 evinrude 7.5
ranger42
im needing a part number for the rod bolt washers the bend flap has broken off. And need replacing. Wounder if a regular lock washer would work
F_R
Honorary Supreme Mariner
I would prefer to see you use a drop of Locktite Screwlock, but be careful not to use too much and get it in the bearing. I would really like to see you use the correct tab locks, all 4 of them. There is a member over at aomci.org that makes them. Or check here at iboats.
EDIT: Part number is 307558
