Kevin60181
Thread starter- Joined
- Jun 30, 2012
- 44
I just gave this a complete tune up, coils, wires, plugs, points, etc. Along with new seals, O-rings in the lower gear case and a complete new water pump.
The engine ran OK, but after the above. It?s running great with higher RMP?s and smother.
Now, mostly when it?s cold and at idle, there is a loud clunk noise and the engine almost stalls for a second as the engine jerks. It happens now & then.
The clunk noise is a lot louder than in the video. Once the engine is warmed up this rarely happens, nor does this happen when in gear. ????
Open to your ideas and suggestions!
Here's the Video on You Tube:
http://youtu.be/Cl1gm5tUS2g
