pro-crastinator
Thread starter- Joined
- Dec 12, 2013
- 453
1956 Evinrude big twin 30 hp,
the saga continues. Present status ? Pulled boat to lake where it will keep the Cobia company. Magneto assembled, checked, rechecked, points cleaned with lacquer thinner, stuck in water can, attached fuel system, and eventually got her running a sweet idle song. I can say that the initial start up weeks ago sucked in comparison. It clearly was only pounding one cylinder at that time. Much smoother now. Thanks everybody for the hand holding.
Question 1 -pic 1 : Should a thermostat replacement be on my to-do list? Never noticed it before, look at pic showing discoloration of top cyl - presumably from an overheat event.
Question 2 - Problem: Fuel delivery on the 56 is from a pressurized tank that is sustained by pressure supplied from carb. When I pressurize my ?tank? ? I am unable to achieve positive pressure to force fuel thru the line. The problem is the carb pressure line, and its inability to hold pressure from the tank. This is before ignition is even attempted. I was pumping tank ? watching fuel bowl, waiting for the nice blue color of 16 to 1 pre mix to fill the bowl ? but that didn't happen until I pulled the carb line and plugged it on the tank side. Fuel flowed immediately. Happy camper mode achieved. I HAVE NOT rebuilt carb ? yet. Out of fear most likely, although my screen name may have something to-do with it.
Iam guessing that the advice will be to pull carb and rebuild it. In hindsight, I should have checked for positive pressure coming from the carb pressure line while motor was running. Oh well.
The rest of the story: My fuel tank is a perfect example of redneck perfection. It consists of a half gallon GLASS mason jar with a lid from the mityvac company that lets me duplicate the pressure tank system from the 50's using a MityVac hand pump that supplies the positive pressure . I am unable to use the tank I have because of the 5 lbs of rust and scale sitting in the bottom. Yes, I have an eye out for a new one. If worst comes to worst, I'll make one out of a old expired propane tank or a hydraulic reservoir tank or something. I just want it to be KLEAN cause we all know fuel probs are high on the list of tripwires.
SO, until I get a ?more durable? fuel tank, I don't think I'll be dipping the boat in the lakewater.
OR if I figure out a motor flush adapter hookup for the 1956. That would be sweet ? and it would be a great way to get the motor in gear to see what the higher rpm's looked and sounded like
Pic 2 - the bottom bolt that I did not loosen to complete the removal of lower end.
Pic 3 - The screw I took out and put back. Notice milky slime that will soon be replaced with fresh.
Is there a need to clean the muck out of there?
