1956 FD-10 lower crankshaft seal question
Minnow00
If the seal starts leaking water into the power head what would the first symptoms be on engine operation? I presume a guy would have to remove the power head to check the seal?
F_R
Re: 1956 FD-10 lower crankshaft seal question
Unfortunatly, like high blood pressure, it is the silent killer. It will run just fine without the seal. The first symptom usually is destroyed roller bearings. By then it is too late. Yes, you have to remove the powerhead.
