1946Zephyr
- Joined
- Oct 21, 2008
- 5,556
Re: 1956 Johnson 15hp Seahorse Resto
You will need to remove the three 1/2" nuts on the front half, which you'll find above the lower shroud and the five 1/4" slot head screws on the rear half, which you'll find below the lower shroud. You'll most likely find it's a better idea to remove the flywheel and the mag plate, as well as the rest of the accessories, before you remove the powerhead though.
You can actually see what the base gasket looks like, in the exploded diagram, on item #4
http://www.marineengine.com/parts/v...ntage-evinrude-johnson/376748/37674800001.htm
