Re: 1956 Lark 30 vs. 1958 Big Twin 35
Though similar, I don't think the lower units are the same. Might be some subtle variations in the internals. Check things closely when you've got them apart before swapping things around...
This is what I have found so far comparing the '55 BT25 and '58 BT35 Lower Units
My '58 35 has rust, damage is limited to the rear propshaft bearing and lower drive shaft bearing
So far the only difference I see between the 2 lowers, is the pin that the shift bell crank rides on. On the '58 35 that pin is a screw, on the '55 25 its just a pin that sits inside the lower unit casting.
Propshafts appear to be the same, lower unit castings physically bolt up.
Rear propshaft bearing numbers are the same.
Every thing in the 25 lower unit looks good, it had what looks like black pourable grease instead of gear oil with no signs of water.
Now as for breaking the stainless screws that hold the water pump housing, I am fortuneate that only the heads broke off, I think with some time soaking with PB Blaster and a little heat I may be able to get these removed.
Shift lever is still stuck after removing lower unit, I did find a thin nut sitting in the top of the waterpump housing, at this time I suspect the nut came from the shift rod connection under the power head.
I guess the power will come off next. I suspect the other nut is jammed up there and thats what is keeping the shifter from moving.
I NEED to do the coils on this engine.
