1957 18 hp Johnson FD-11 Pinion gear part number help
stwaller
I have a 1957 18 hp Johnson FD-11 that my son and I are starting to work on. I believe the pinion gear has some wear and wanted to replace it. He's my problem. The parts manual only gives you a part number of 377147. That's for the whole assembly. I was hoping to get the individual part numbers of everything in the assembly. Any help would be appreciated.
Crosbyman
try here at IBOATS for parts ... they support this site and may very well have all you need .if not try the oldies site at AOMCI "ask a member" free classidied adds/wants
F_R
If the pinion gear shows obvious wear, you can bet the other gears are worn also. And bearings/bushings. Do some better diagnosing before spending $$$.
stwaller
After doing some more investigating, the gears look just fine.
