1957 35hp Big Twin Fuel pump nipples!! yes fuel nipple
Squirrel42
What nipple behind the carb is my pulse nipple and and Shutoff nipple. I got a nipple below carb and a nipple a little higher behind the electric starter.
I installed a fuel pump for single fuel line and need to know what nipple needs to be clamped off.
Thank you in advanced!
pro-crastinator
No Title
Here's a pic of the nipple in question - next to a 1/4 inch bolt (for perspective)
I THINK (guess) that makes the nipple 1/8 inch pipe thread - which I have never seen before. (I lead a sheltered life)
Pic 2 is the nipple mounted to a crappy clear tube. Nipple is mounted at the base of the cover to the reed valves.
Note that pics are from a 1956 Big twin 30hp. Exactly the same only different.
This is the nipple that pressurizes the fuel tank - not to be confused with a pulse line that pushes a fuel pump.
Squirrel42
No Title
So i can plug that nipple in the picture that pressurisizes the gas tank and connect this unit in the picture to nipple behind my starter
Squirrel42
That was it, thanks for the answer! Now i can get it to start but back firers and quits. It looks like a carb problem to me.
its spiting fuel out the carb, must be something with float or needle.
