1957 35HP Big Twin (hitting hard Knocking)
bigballerg
Re: 1957 35HP Big Twin (hitting hard Knocking)
Agree...hey, maybe its still under factory warranty :)
boobie
I've never seen one that bad either. I've seen the alum burned away from a blown head gasket but not cracked like that. Do you want OMC'S customer service phone #?? :lol: Just a joke.
bigballerg
I actually talked with the guy who sold me the lower unit that was bad to start with..he is going to give me his 40 hp Johnson as swap and sell out mine for parts.... The 40 is compatible with my other components. Some good news on a crappy day.
boobie
Keep us posted as to what happens.
bigballerg
I pulled this part off circular looking on the floor there?? What is it? has fuel nipple on it I think? IMAG0073.jpg
nwcove
looks like a lu from a trolling motor. lol need a better pic.
bigballerg
The wire in the fore front goes on this part... reason I took picture to remember :) It came off the side of the block....
nwcove
the whole part is the lower cowl section you removed to get at the bottom head bolts.
bigballerg
I placed this part on the Cowl section.... Im taking about the part on it?? sorry for not being more clear..
bigballerg
What does it do??? Cut out fuel to motor?
nwcove
the gizmo attached to it looks a whole lot like a vacuum cut out switch.
nwcove
it kills spark to one cylinder if the motor is over revving
bigballerg
I see... Well, tomorrow I get an upgrade I think? to a 40hp Johnson (60 model or so I think) and put all my components back on it... We will see how that fires up on the 1st attempt? Thanks for the info as always!!
nwcove
not sure if the 40 is an upgrade or not! the 57 bigtwin is a much nicer looking motor. jmo ( id still keep it and look for a powerhead!)
bigballerg
ok, so I got a Evinrude 25532 ? I believe its a 1957 35hp Lark? Anyway, need help. This sucker would not even budge on crank. After soaking a night and playing hit sledgehammer on 2x4 on crank wheel it now moves freely. So, I hooked it up to battery and gave it a whirl. It cranks and spins, BUT without spark Plugs... When I put spark plugs in it wont crank and spin? What gives???
nwcove
you did what with a 2x4 and sledge hammer??? :eek:
as far as the cranking problem goes, id look into weak battery, loose or corroded connections, or frayed wires. you can usually narrow them down by feeling for hot spots at the connections and through out the harness.
HighTrim
It cannot overcome the compression. Weak battery, corrroded cables, dirty/loose connections are where I would start.
