1957 35hp johnson
Mikec53
I changed points in my motor. It has great spark. Took boat to the lake. It started on 2nd pull and ran about 10 seconds then died. It wouldn't even sputter after that. Before I changed the points it was very cold blooded. When I did get it to run it ran great then suddenly died. That's when I pulled the flywheel and discovered the points for bottom cylinder were way out of adjustment. Was so worn couldn't get close to specs. Now I did a compression check. I pulled it 3 times on each cylinder. Both came out on the gauge at 90 psi. Is that ok? Just trying to figure it out. Its frustrating. I just bought the motor a couple weeks ago for a great deal.
Pressure tank in good condition and with cap closed ?-----Post picture of the magneto.-----Is the oiler wick for magneto cam in place?
oldboat1
^+1 on the pressure tank. I would replace coils, points, condensers, plugs and plug wires along with the impeller. '58 takes the wire core 7mm plugs to coils.
Inspect parts before rushing out to invest beer tokens in new parts.
oldboat1
Coils cost a few tokens -- probably good to go if the casings are not cracked.
Mikec53
Yes pressure tank is good. Cap seals when closed, the primer in it works and also builds pressure when motor is running. The oiler wick is in place on cam.
Mikec53
I replaced the points and condensers. I checked the coils and they were good. I tested spark after I put it back together. Has nice strong spark on both cylinders. Fuel tank is good also.
oldboat1
low to mid 120s psi on a pair of '57s I had three or four years ago. Maybe a new head gasket or a retorque of the current one would help on yours, or just running the motor. If you have the sintered filter in a glass bowl, try it without the filter. For the bowl, a good flexible gasket is critical.
jimmbo
Yes has good spark. I'm thinking it mite be a fuel problem. Found out motor Has been sitting since 2018. Has 90 psi compression on both cylinders.
When taking the Compression, was it done cranking the Motor with the Starter, or using the Recoil? If using the Recoil, that Engine has a Compression Relief System which lowers the Compression to make it easier to pull the Rope, and it would need to be disabled to get the true Compression numbers. If cranking the engine with the Starting Motor, ignore the last Sentence
hardwater fisherman
You said you pulled the rope 3 times to check compression. You should pull until the needle stops moving. So perhaps the compression is actually higher?
Mikec53
Oh ok. It only has pull start. I'll have to disconnect the pressure relief and see what results I get.
oldboat1
Maybe pull both plugs while testing, cranking/pulling over until needle stops, as indicated. (Throttle does not need to be open on a 2-cycle.)
Mikec53
Is this the nut I would loosen to adjust the needles for low and high lean/rich? They are in front of the air intake box and behind the front cover plate.
jimmbo
That is why the Mixture Needles extend out of the motor cowling, so you can adjust them
Back in the day most folks learned how to adjust the carburetor.----You had to compensate for local atmospheric conditions .----Compensate for water temperature.----The adjustments were right there for a operator to use while underway to the fishing hole.
