BlackoutBill21
Thread starter- Joined
- Dec 10, 2016
- 181
So This motor was seized and I tore the block apart for education purposes. after honing the cylinders i realized The block was in great shape. so I ordered some new rings, and put her back together.
SHe idles like a boss! runs really well otherwise.. Now the problem is at high speed after about 30 sec, she cuts out and dies.
putt the choke on she starts right back up, and after putting the choke back in, she lean sneezes like crazy then eventually riches out and goes back to the best idling motor ive ever heard. I had it idling for 2 hours straight.
side notes. new fuel pump, i converted it from the duel line tank to single using the vacuum cap method.
also new fuel lines/ carb kit/ coils plugs and condensors. spark jumps over 3/8. Also tried a brand new primer bulb with same results.
This test was all in the barrel. never on the water.
any ideas?
any ideas?
