1957 evenrude 5.5
kbait
Blow air up water tube to see if it’s clear. Check that said tube is indeed inserted into waterpump housing grommet.
But first, if barrel testing, make sure waterpump is completely submerged before starting (lower unit bolts 6” under water).
Good luck!
johnwb
Thanks !!! kbait the water level did the trick. I was just too shallow.
oldboat1
Maybe not so fast. If the motor was run with the impeller dry/out of water, it could have be destroyed in a few seconds. I would at least have a look at it.
