1957 Evinrude 18 hp need help
Brymill
Hi guys, I rebuilt the carb on my 18 hp evinrude and converted it to a fuel pump using a 3 line pump (18-7353) and it seems to work fine. The only problem I have is I'm getting a little fuel leaking at the high speed needle adjustment. Its got new packings and I've tightened them down but still getting some fuel leaking. Should I be concerned?
rjezuit
Re: 1957 Evinrude 18 hp need help
Be sure the old stuff is cleaned out and add some more packing. Tighten the nut until snug, let it sit awhile, or run it a while and then re-tighten. You do not want to leak gas anywhere. Rick
