1957Evin
Thread starter- Joined
- Nov 16, 2008
- 6
Hi all outboard enthusiasts! Thank you for all your help in advance and for all the help you have provided via this forum that has assisted with past projects.
This summer I acquired a 1957 Evinrude 18hp Fastwin. I gave it a test run and didn't have much trouble getting it to run, but it did run rough. The first thing I noticed was very little cooling water was being discharged when it idled. When I cranked the throttle up, the discharge water increased, but not to levels you would expect. The other interesting thing I noticed was although the engine ran at very high RPMs the power output was marginal. It was acting like the propeller was slipping.
I took the lower unit apart and checked the water pump and the drive shaft. The drive shaft was chipped. I disassembled the motor and fit the crank shaft together with the drive shaft and discovered they did not mesh very well and although I could not get them to slip, there was a lot of play.
Upon further investigation I discovered an O-ring was stuck inside where the drive shaft fits into the crankshaft. After removing the O-ring the drive shaft went further into the crankshaft and all play disappeared. They made a tight fit.
Do any of you think I need to replace the crank shaft and drive shaft since the drive shaft did get damaged a bit (there are noticeable chips on the outside of the splines)?
Thank you for your help!
