Hello to all,just found this forum.
Hoping to bug you a little over this old 7.5 I just picked up from a guy at work that said it ran good.I was going over it before trying to run it,checking points&such.i noted a couple possible problem areas.According to my local dealer,it needs at least 100lbs comp cold.I noted 68-70lbs on both cylinders with throttle fully open.It was very even,just maybe low.I checked my later model 8 Johnson,and 15 Evinrude.They had 110 and 120lbs.I also checked the carb on the old 7.5,and it was clean.I gapped the points@ .o20",and filed them a little.I then hooked up gas,loosened cap,pumped button till tight,choked and it started 2nd pull.I had to turn fast carb screw in till it was just out 1/4 turn to get it to accelerate.I set low speed out 1.5 turns.
after I ran it 10 minutes or so,it seemed to run fairly good.I`m hoping to try it on water in a week or so,I had it in trash can tonight.The last fella put a water pump&head gasket on it.
My question is does it have a good chance of running good with this low of compression,and does the lack of compression have something to do with having to turn fast carb screw in so far&will this keep fuel pressure up?I also noticed a high pressure water leal at maybe a freeze plug,it was on right rear of head on bottom,maybe .5 in diameter.If any of you work on these old moters,appreciate any tips!Thanks,Dizz
