Re: 1957 evinrude 7.5 lower gear oil?
Pump oil into the lower (drain) hole till it comes out the upper (vent) hole. Replace upper plug before removing filler from lower one. Then quickly replace the lower plug. DO NOT remove the phillips head screw!!!!
Yes, 90 weight gear oil. Or 80-90.
