1957 evinrude big twin
thekornkid
hi, we've got a 1957 evinrude big twin 35 and we need to know:<br />1. spark plug gap and type of spark plug/part no.<br />2. valve intake and exhaust gap, warm or cold<br />3. type of points and where to get them<br />4. fuel mixture<br />5. what do you do with the low and high speed adjusts, explain please...<br />6. what about the timing?<br />thank you very very much
Chinewalker
Re: 1957 evinrude big twin
1. Spark Plug: Champion J6C gapped at .030"<br />2. No valves to worry about - it's a two-stroke.<br />3. Points are available through a Johnrude dealer, part #580148 or NAPA, part #18-5156, gapped at .020"<br />4. 32:1 mix using good quality TCW-3 rated oil and good quality gas (I prefer 89 - more consistent quality).<br />5. High & low speed needles - close them (gently) and then re-open them: Bottom 1 full turn, top 1 1/2 turns. Start motor and allow to warm up. With motor under load, wide open throttle, turn high speed needle (bottom one) clockwise, motor will pick up revs and then fall off. Back out 1/4 turn from that point. Do the same with the low speed, in gear, turning inwards until motor sneezes, then back it out 1/8 turn from that point.<br />6. Timing is automatically set when you set the point gap at the high point of the point cam.<br />- Scott
