Squirrel42
Thread starter- Joined
- Mar 23, 2016
- 109
I have recently resurrected a 1957 35hp Evinrude lark. Carb rebuild, New points, Condensers, Spark plug leads, boots, springs. Complete over haul of lower gear case, with all new seals. I'm so ready for this to be done. Fired her up and she sounds great, than this BS!
Cannot get my engine to run with out constantly squeezing the fuel bulb from the tank.
I have the Sierra 18-7351 Fuel pump installed.
Drilled and tapped the recommended bypass port and installed pump with gasket over the correct drilled hole.
Installed it Upside down and Right side up, no change, still squeezing!
I have tried two fuel tanks and still the same problem.
I can pump it until its rock hard but after the engine runs for 30 seconds it eats all the fuel, revs high and dies.
Something is not pumping!
My best guess now is possible faulty pump?
I own a 15hp Evinrude 1973, Could i take the pump off it and do a test? I have a feeling the pump may be to small to test it!
Please help!
Please help!
